Arlo video doorbell,
  • 2 Replies
  • 1905 Views
Habbie2
Firmware 1.8.0.0_4_4a16fed_58744c
Recently a small amber / orange disc has appeared in the middle of my doorbell, between the bell push and the LED.
I have no idea what this is.
Can anyone help please?
Habbie2
Hi Stephen. Many thanks for your response. It must be the IR as you say , anyway it has become visible I don’t know.
i did try removing the battery but will try again.
The bell is working fine and recording as normal so a bit of a mystery.
cheers.
Iain
I think you are looking at the spot where the IR LED for nightvision is located. There is a light sensor just above it. See page 6 here for a diagram:
On my AVD2001, the IR LED isn't visible at all in daylight (It is hidden by the plastic shell over it).  The IR LED would normally be on only when
  • the light sensor just above it detects that it is dark outside
  • and the camera is active (streaming or recording)
The light sensor is visible, but shouldn't be lit.
Does your video look ok?
Have you tried removing/reinserting the battery to reboot the doorbell?
Habbie2
cheers.
Iain
  • 2 Replies
  • 1906 Views
