- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Re: Arlo Wireless Doorbell + what screen do I buy?
Hi,
I want to buy a Arlo wireless door bell, but I want some kind of screen inside to see who is ringing, cant find any option to buy a set like that so I ask if there is any screen that I can hang on the wall that will work with the Arlo doorbell?
JagVet2021,
The doorbell is designed to work with a mobile device using the Arlo Mobile App. When the doorbell button is pressed, the mobile device will receive a call indicating someone has pushed the button.
Yes Ive seen it online, but I dont want to check my phone every time some one rings the bell, thats why I wanted a screen like near the door to show who is on the other side. So there is no option like that for this doorbell?
JagVet2021,
You may be able to accomplish this using an Alexa or Google Assistant device. Take a look here for more information on these integrations:
Arlo integration with Google makes it easier to protect & connect
How can I use my Arlo Doorbell with Amazon Alexa?
