Are there any door mounts on the market for the wire free doorbell? I can't drill because I'm renting.
Hi @Thisstinks
Arlo does not have any door mount accessories at this time. I personally have used a sticky gorilla tape to mount a doorbell in the past. This was for our first generation doorbell that was a smaller diameter.
Anch'io vorrei sapere se c'è qualche supporto per la porta esterna di casa. Grazie
As @ShayneS has already suggested: double sided tape is good (though mind to use a good one, as otherwise it'll peel off the paint, too.)
Even though I'm not renting, I removed the peeping tom and put a screw there instead to mount the doorbell. You can get some a nice blanking plate on the inside.
