ARLO DOORBELL WIREFREE Quality ?
  • 1 Reply
  • 638 Views
Asavar
Hi
I bought this new wirefree doorbell, installed it and it works quite well at the moment.
I am stil unhappy with the fact that it does not connect with my arlo pro 3 base station
If it did i should be able to save the pictures and movies locally instead of the cloud.
But i have a doubt on quality, having taken off all the plastic when unboxing, it seems that there is still a peel of plastic that i can not remove, on half of the doorbell.Difficult to say if it is normal or not and it get scrached very easily.
Can someone having the same model tell me if they are all like this or what to do ?
Look at the picture below
Thanks in advance for your help
(Also posted in french community but with no answers 😣
Asavar
1) I anticipate a firmware release that will allow the wireless doorbell to connect to a base or hub. However, I can't say for sure when or if that will happen.
2) Leave that "film" alone - it's not something that should be removed.
  • 1 Reply
  • 639 Views
