Won't stop alerting!
  • 494 Views
MSkar
My doorbell's began alerting me to every movement up to 15ft into the street. I turned off all the alerts and set a 4" zone but it still notifies me. Anyone else having this issue in the last 2-3 days?
Have you tried rebooting the doorbell?
MSkar
@jguerdat Yes. No difference.
While there are likely a bunch of things to try, the fastest thing to try is to remove the doorbell and reinstall it. You'll need to check your modes and rules to make sure they are still appropriate.
