- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- Re: Video doorbell AVD4001 wont connect to Wi-Fi
I go to add the 2nd gen doorbell, I get through the pairing process to where it tries to add to my account. Just before it fails, the amber light starts blinking for about 10 secdonds and I get the "doorbell to connect" message. It shows up on the app, but I can't connect to it. I've done the reset procedure to see if that helps, but same result. Any assistance would be greatly appreciated!
This sounds like it might be something going on with your wifi network.
Is it set to use WPA2 (AES) security?
The scanning tool I'm referring to is the one embedded within the Arlo app (using Iphone 14) . The only choices I have are WPA2+personal, WPA2+WPA3-Personal, WPA+Personal / WP2-Personal, WPA3-Personal.
I did and same result. The doorbell acts like it's join the network, I see my Alexa device pick it up and it gets all the way to the end, then the amber light flickers for about 10 seconds and it fails. Thanks for trying to help, but it seems to be either a faulty device or something internal to Arlo itself.
@whtabtbill wrote:
I have these devices set up on their own separate 2.4 GHz network. My phone is also on that network when I connect them. Appreciate your help, but I’ve already ran their scanning tool and it reports no issues.
If this is a guest network, make sure "Allow guests to see each other and access my local network" is checked.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
