Video Doorbell Recording Settings
My Arlo Video Doorbell is installed on my front door, which faces a very busy street with foot traffic passing by every few seconds. Recording every motion or movement detected is pointless.
Is it possible to configure the app to only record when the doorbell is pressed and ignore all other motion or movement?
AFAIK, it has to be motion-activated, not button pressing. You can reduce the motion sensitivity in your modes and rules (if using the interface that uses Library to view recordings) or the doorbell settings under Default Mode Settings (if using the interface that uses Feed).
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
