Solar panel
  • 1 Reply
  • 729 Views
Grubby123
Is it possible to connect a solar panel to 2nd Generation door bell ?
 Thanks for your help
No. The only method to keep the battery charged is to use any existing wiring from an appropriate transformer. If your house, like mine, doesn't have that wiring, search for a suitable plug-in transformer that could be attached to the doorbell. Here's one example but there are others:
https://www.amazon.com/Doorbell-Transformer%EF%BC%8C33-24V500mA-Adapter-Compatible/dp/B0CF8BRBLS/ref...
