Is it possible to connect a solar panel to 2nd Generation door bell ?
Thanks for your help
No. The only method to keep the battery charged is to use any existing wiring from an appropriate transformer. If your house, like mine, doesn't have that wiring, search for a suitable plug-in transformer that could be attached to the doorbell. Here's one example but there are others:
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
