Routines/modes to trigger chime/chimes problem solved
  • 0 Replies
  • 304 Views
  • 1 In Conversation
brendan185
After some frustrating hours of trying to get my Ultra 2 cameras and wireless doorbell (gen 2) to trigger my chime 2 and chime 1 i finally figured it out and am writing this in hope to save somebody the frustration.
So if you are having trouble getting your chime to play a melody/sound from motion triggered from cameras or doorbell, what worked for me i used the online version of Arlo and i also deleted the current modes that i had saved in my routines, started over then was able to properly SAVE the modes then they work as they should. One other thing i noticed after doing so is i then noticed the chimes appeared on my dashboard which they hadn't on my Arlo app.
Hope yous get it figured out because they are a good security system when they are working.
Thanks.
0 REPLIES 0
