With all the other doorbells I have had the live stream was recordable on my home security NVR using the IP address like any other security camera. What are the settings to configure for this camera in the NVR, ie... port, protocol etc.
It's not possible with Arlo. You can record locally if you use a hub to connect the cameras to but not to a networked drive. Once a month I remove the drive and copy it to my NAS for permanent storage.
Thanks for your reply. Yeah after a bit of digging that's the conclusion I came to. It's useless to me unless I can use it with the rest of my system. Returned the device this morning.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
