  • 1 Reply
  • 1521 Views
dcntstak
How do I get my doorbell to activate chime2 when motion is detected but doorbell is not rung?
Assuming you are using the new interface that uses Feed to view recordings, edit your modes and the rules for the doorbell. Choose to Add an Action and then Play a Sound. You should find the chime there to select and finally be able to select an appropriate sound.
