- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- Chime buzzing 1 week after installing video doorbe...
Chime buzzing 1 week after installing video doorbell
I purchased two Arlo 2nd generation doorbell cams - 1 for front door and one for back door. I set them up in the wired configuration. I used my existing transformer and chime. I did not add or use any Arlo power products. About a week after installing the doorbell, I heard a loud buzzing noise coming from the chime. I figured the chime was bad so I get a new one from Lowe's. Same problem after install. Ok, maybe the transformer is bad. I go back to Lowe's and buy a transformer. I set it up for 18V and install it. Still have the same buzzing noise. If it's not the chime, and it's not the transformer, what could be wrong?
It certainly could be one of the doorbells.
Try disconnecting the front doorbell, and see if the buzz stops. If it continues, then reconnect the front doorbell and disconnect the back, and see if that eliminates the buzz.
Unfortunately, that did not help. My neighbor told me he had a similar problem with his system. The installer came back out and installed a "resistor" and the buzzing stopped. It was years ago, and the tech no longer works for the installation company.
The wired doorbell (AVD1001) required a power kit, but the 2nd Gen doorbell does not. FWIW this is not a resistor.
Are you saying that the buzz continued with either doorbell connected (not both at the same time)?
What model chime do you have?
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
