Battery no good
Does Arlo sell a bell charger for the 2ng gen door bell or can anyone suggest a suitable device. In less than a year I have to charge it every 3 weeks. And this is useless and you can’t buy a replacement battery. The obsolescence is part of the design.
They do not.
@jguerdat uses a plug-in transformer - I don't know which one.
There are quite a few out there, including these
- https://www.amazon.com/VIIVRIA-Transformer-Compatible-Honeywell-Thermostats/dp/B0DCVS1HXP
- https://www.amazon.com/Doorbell-Transformer-Thermostat-Compatible-Honeywell/dp/B0D3LS7D64
They are all pretty similar in price.
I only used one when the original wired doorbell came out. My house had been re-sided and the doorbell wires weren't available so the plug-in transformer was my solution. That model isn't available any more but, as noted above, there are plenty to choose from.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
