Avd1001 wired to avd4001 wired.
  • 1 Reply
  • 585 Views
Tman1788
Does anyone have wiring diagrams for these. I have an 18v transformer. The AVD1001 camera lens was broke. Can I install the adv4001 in wired configuration as is, or do I need to revert the wiring in my existing original mechanical chime.  I still want the original mechanical chime to work like a traditional chime.
The only thing you need to do is to remove the power kit that you should have attached to your chime with the original doorbell. Otherwise it should just work as before.
