I can not connect Chime 2 to my doorbell. I have the latest app. I have tryet 10 times with no luck
Problem solved. I installed it on my iPad
blund,
What model mobile device are you using to install the Chime 2? Do you have a different mobile device you could use to see if you still experience the same behavior?
I use iPhone 15 Pro. The problem is that my phone not can Connect to Arlo network.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
intermittent
Mechanical chime
no app model
noise
Phonecall
Secure Plus plan
Secure Trial Active
speaker
Talk
wired
Wmb4540
