AVD4001 Mounting Plate Screw Spacing?
  • 2 Replies
  • 1456 Views
Philipm28
What is the distance between the two screws on the plastic mounting plate?  I'm planning to replace my NuTone intercom door speaker with an adapter plate with a 4.5" screw spacing.
Thanks.
ShayneS
Hi @Philipm28
The spacing from the top to bottom holes on the bracket is 4". Hopefully that helps.
ShayneS
Hi @Philipm28
Philipm28
Thank you!
