after I added camera 4, camera 2 totally disappeared. it won't let me add it again.
You are having trouble with your Arlo camera setup. Here are some steps you can try to resolve the issue:
Restart the Arlo Base Station: Unplug it for about 10 seconds and then plug it back in.
Check Camera Status: Ensure that Camera 2 is powered on and within range of the base station. If the battery is low, recharge it.
Re-sync Camera 2: Press the sync button on the base station, then press the sync button on Camera 2. The camera should reconnect to the base station.
Check the App: Make sure your Arlo app is updated to the latest version. Sometimes, bugs are fixed in updates.
Remove and Re-add Camera: If you see Camera 2 in the app but can't access it, try removing it from the device list (if possible) and then re-adding it.
Factory Reset (if necessary): As a last resort, you may want to factory reset Camera 2. Refer to the user manual for instructions, but keep in mind that this will erase all settings.
Hope that helps!
@LauraMajor were you able to get your camera back online?
Accessing Local Storage
