If I connect the cameras directly to the wifi, and the base station is on the same network, can I still have local recording or do the cameras need to be on the base station’s built-in wifi for that? Seems like a very common setup but can’t find a definitive answer besides suggestions to buy a second base station.
@dnak wrote:
Thanks. So it’s not that they need to be on the same network, it is that they need to be on the internal wifi?
Ultra and Ultra 2 cameras can only connect to the closed base station wifi. Pro 3 floodlight, Pro 4, and Essential cameras give you the choice of connecting to either directly to home wifi or a base.
But in all cases, local storage requires the camera to be connected to the base wifi.
The cameras need to be on the base station's wifi.
Accessing Local Storage
