  • 7740 Views
  • 2 Likes
CANetUser
What voltage and wattage do the Arlo Ultra cameras require during operation and standby?
What is the power output range of the Arlo Ultra solar panel?
Don't forget that the rated output of the charger includes a safety buffer - the camera very likley draws less than that, even when operating. I don't know how much buffer is included but a 2A USB charger is pretty typical for most devices these days.
The solar panel is just a trickle charger and will charge with the battery installed. The current output is going to be small, even in strong light. The Pro cameras will still discharge the batteries when used heavily even though a solar panel is connected - I'd expect nothing less with Ultra.
Ultra requires;
5v@2A is the output of adapter
( tho at standby prob  very little ; guessament less than 50ma )
CANetUser
Thank you TomMac
10 W sounds like pretty high draw for a camera. Is the cable/adapter a standard USB power adapter? If the Ultra is on DC power or powered by the solar panel does the battery charge while it is in the camera or does the battery need to be removed in order to charge?
Any idea what the expected power output of the solar panel will be?
  • 7741 Views
  • 2 Likes
