View linked trigger recordings
This is a new problem if camera a is set to record and activate camera b and vise versa, when you try to view one of the cameras recordings it will only show the what I believe is the trigger camera footage, everytime! I can select camera "b" but it will keep bringing up "a" until I delete "a" then can view "b" Also the viewed footage needs easy access to a delete function, not have get to it via 3 dot menu!
I'd recreate the rule to see if that helps.
I'd also NOT delete any video since there are too many requests to get them back. Just let them fall off the library according to your plan.
Recreating rule doesn't help, issue is still present
I had the same problem last night when we were gone and the neighbors car walked across the driveway and triggered 3 cameras to record. When I try to view the driveway or front yard cam it only shows the backyard.
This is BS - I didn't pay $$$ to have the system break every other day.
Accessing Local Storage
