I recently started to experience the error, “Videos stored on Base Station are not available. Please check connection settings.” when trying to access locally stored videos in the Library (I have a VMB5000r5 base station recording to a microSD card).
I have previously been able to access videos with Port Forwarding enabled and also without Port Forwarding when connected to my home network.
I have again disabled Port Forwarding and am connected on my home network, but still receive the same error.
i can see from the storage setting info that my microSD card appears to be saving videos as the amount of space used is increasing.
Anyone else experiencing this error recently? Thanks.
Best answers
If you are still experiencing this symptom, please make sure that the forwarded ports have been setup on the router.
To check if the forwarded ports from the app are open, you can utilize the below port checkers:
https://portchecker.co
https://www.yougetsignal.com/tools/open-ports/
https://canyouseeme.org/If the ports are still closed, the router's firewall or ISP can still be blocking the ports. Please reach out to your ISP or router manufacturer for further assistance.
No, my problem is solved. I had already updated to 5.01 but that did not solve things. I then did an IOS update and that took care of the problem.
The development team is working on the fix for the issue with the remote access. I will provide another update as soon as I have more information related to the release.
Thank you for your patience
Absolutely
I’d recommend everyone leave a 1 star review on the App Store. They seemed to take offense when I did that last week. Also, give the Arlo devices bad reviews on Amazon so that others don’t waste their money like we did. I had to purchase new cameras and doorbell camera from a new vendor last week.
Removing a camera fixed it for me too. Just had to add it again afterwards
Check message 353. It worked for me
I have the exact same issue - Arlo please support
I've had the same issue for at least 2 months. My Android phone is able to view the storage and clips using port forwarding, though my iOS device will not show the clips and their Library with error message. If this is result of an update by Arlo for ios, why can't this be fixed in a reasonable time frame!
100%. This is becoming ridiculous. I guess Arlo is trying to phase out this freebie and make you subscribe to their cloud service
Yes, that has also crossed my mind.
However, doing that on products already out there and in operation is simply not an option!
Changes like that needs to be communicated well in advance and only apply to new products.
Netgear solution was to do a port forward which I did and that's how I got port 80 open. I don't have parental control turned on.
I bought a new router so we'll see if that solves my problem will let you all know.
thanks for the replies I appreciate it.
@Arlo please support
Arlo, not Netgear. Netgear divested Arlo back in 2018.
More importantly, as I said above, it's not the right advice. I recommend deleting the port forwarding rule. Generally it's bad practice to forward ports unnecessarily, and that definitely applies to ports 80 and 443 (which carry almost all the traffic on the internet).
so ridiculous that there has been no update in over two months. are they waiting for people to get desperate and subscribe instead?
Port forwarding still not working.
iOS 17.6.1
Arlo 4.19
VMB4540r2
Hi, port forwarding not working anymore with iPhone (currently iOS 17.6.1)
It just stopped working after release of 4.14 or around that version. I have not changed any settings from my side.
Is this addressed by Arlo?
Br Erik
I have the same problem and Arlo has done nothing for over six months we all need to ask for a refund as they have some the don’t care
My Arlo SmartHUB is repeatedly attempting to send TCP traffic on port 4000 to network 172.14.1.0/24 network IPs. It is also trying to send ICMP and UDP traffic to those destinations as well? Why?
Those addresses appear to be assigned to AT&T. Do you have an AT&T phone?
I do not have any type service using ATT IP address space. I don't use ATT services. I really want an answer to this question. Makes me wonder if the firmware is infected with a backdoor trojan. Just what I need, a backdoor into my Arlo camera system.
Port 4000 is a bit concerning. Are you also seeing traffic on 7871 or 11271?
I am tagging @JamesC so he can look into this for you. Can you check the specific IP addresses you posted? AWS does use some 172.x.x.x addresses, and Arlo definitly uses the AWS cloud. No idea if they have any servers hosted by AT&T.
I’ve successfully set up port forwarding before but recently it has become not available. It works on my android devices but not apple ever since the new IOS 17.5 update came out. Is anyone else having this issue? I’ve tried contacting support both with Arlo and Apple but they’ve been no help.
This is a bug in the iOS app, and there is nothing you can do to resolve it. It's not clear its linked to 17.5, since Arlo released an app update at about the same time.
It's been broken for almost 3 months now, and unfortunately Arlo hasn't given a timeframe for fixing it.
The VPN alternative does work, but can be harder to set up. So maybe check to see if your router has a built-in VPN server. (Netgear Nighthawk and Orbi routers have this feature, as do higher-end routers from some other manufacturers).
I'm at wit's end. I absolutely hate my Arlo because what's the point in having it if I cannot watch recordings of people at my house for my cell phone! Every time I try it tells me to try again and does not load the videos. If I'm at home using my cell phone it will load the videos. Whoop-Dee-Doo! If I'm home I can see who's at my house! I can watch live but only if whatever is happening. I'm able to get to my cell phone in time to see it. This has happened since day one. I am so frustrated and about ready to switch to blink. What can I do to fix this? Talking through support does not ever help! I've updated everything. There's no updates to do.
I am able to make port forwarding to my ultra smart hub to work on my iPad but not to my iPhone. Am I missing any extra step? How do I make my iPhone enable my hub’s port forwarding?
Accessing Local Storage
