maharrm
I recently started to experience the error, “Videos stored on Base Station are not available. Please check connection settings.” when trying to access locally stored videos in the Library (I have a VMB5000r5 base station recording to a microSD card).
I have previously been able to access videos with Port Forwarding enabled and also without Port Forwarding when connected to my home network.
I have again disabled Port Forwarding and am connected on my home network, but still receive the same error.
i can see from the storage setting info that my microSD card appears to be saving videos as the amount of space used is increasing.
Anyone else experiencing this error recently? Thanks.
Best answers
  • ShayneS
    Thank you for the feedback, the development team is investing these reports and I will be updating the thread with more information as soon as I receive it.
256 REPLIES 256
dujcym18
Yes, exactly same issue I experienced lately. with port forwarding, I am able to access all cameras, but no able to access vids saved in Base Station.
cammerz
Are you on iOS? I just tried factory resetting mine and setting it all back up but still not working
dujcym18
it is IOS, so this means it is not Arlo issue, rather IOS issue?
gbweir
I'm on IOS 17.5.1
What I did worked for me. Maybe just a coincidence
I've never used port forwarding, so was not an issue
ElToro54
I purchased my Arlo bundle through Costco, so I feel good that I can return it and switch to a different provider if needed.
I have a basic setup with a USB and an external drive, and for the past few years, I’ve been using port forwarding to view video while I’m away. Recently, it stopped working. I have done all the troubleshooting steps:
1. Restart
2. Unplug
3. Contact ISP - confirmed that the ports are open.
4. Change the ports
5. Ensure the ports match
What am I doing wrong?
why isn’t this working anymore?
It seems like a fishy way for consumers to be pushed into purchasing their subscription.
Are you using an iPhone? This is a known issue with iOS.
ElToro54
With no solution?
Henrysky
No, it is not an IOS issue.
I could not find any records in my library when I log in windows' Arlo Web Portal. It SAYS "no recording", but actually all file recorded in my base station USB.
Henrysky
I wish this is an IOS issue, but it is same when I use windows Arlo web portal.
Any Arlo's response? So curious...
zoopy
This will never get fixed. I’m just getting the non stop ads in-app to purchase a subscription plan.. I guess we are out of luck.. Arlos way to take our money
Henrysky
Technically, please make sure this is any IOS issue, the bug comes from current IOS app.
And also, would you like explain why I can not find any recording from my library when I use windows' Arlo web portal?windows' Arlo web portal is also IOS....I do not think so.
Henrysky
That is the root cause?
If that is the root cause, they are ruining they brand and reputation.
Henrysky
Oh, yes.
Port forwarding also not working with the windows with your Arlo web potal.
Henrysky
I do not think it is a good work around.  it is just something work despite the problem
Henrysky
Same thing, not work when use windows' ARLO web portal.
Tim Cook and Bill Gates, they all made this problem with Arlo?
Henrysky
I am not sure any update from Arlo side?
Henrysky
Please change the name--Videos Not Available on Base Station.
Actually, it is port forwarding stop. The videos can be found in USB.
@ElToro54 wrote:
With no solution?
If your router has a VPN server built in, then that will work.  For example, Netgear Nighthawk and Orbi routers have OpenVPN built in.
No other workaround.
Direct access to local storage is only available in the app.  It has never been available from my.arlo.com.
dujcym18
That is correct regarding "Direct access to local storage is only available in the app.  It has never been available from my.arlo.com."
Hi everyone, please allow me to correct the issue we are facing:
1) Direct access to local storagte is only available in app, not web because by no means should Arlo access your home device's storage. If so, it poses huge risk to both Arlo and users from privacy and legal perspective
2) We are talking about access Arlo Cameras and Base Station clips remotely by using port forwarding.
3) I have set up port forwarding, and port forwarding itself is successful. And you can verify your own port forwarding setup by using below link
https://www.portchecktool.com/
4) Obviously my port forwarding is set up correctly because I am able to access all cameras remotely.
5) So what is the issue we are trying to fix? Previously, with port forwarding, I was able to access all cameras linked to base station, as well as acess to video clips saved in Arlo Base Station. Now, I am only able to access all cameras but I am not able to access video saved in Arlo Base Station.
Hope it clarifies
Are you using iOS or Android?  This is a known issue with the current iOS app.   Arlo knows about it, but haven't given a fix date.
The only workaround at present is to set up a home VPN server, and use that instead of port forwarding.  Some high-end routers (Netgear Orbi and Nighthawk to give two examples) have OpenVPN built-in.
I don't understand what you are trying to say here.
Whatever the concern, Direct access to local storage is only available in the app, and not the browser.  The recordings are downloaded directly from the base by the app, they are not traversing the Arlo cloud.
dujcym18
got it. Thanks
Yes, I am using IOS so it is indeed IOS issue.
Pauld33
Been having this issue for more than a month. What it all boils down to is the iOS app update to 4.14 and now 4.15 somehow broke the port forwarding. I have 2 phones - one that I haven’t updated the software since 4.13, and the other where I have. The phone running 4.13 still works, but the one with the newer versions of the app does not work when away from the local network.
I’ve gone through all the troubleshooting and did it again with the support chat today and even after reinstalling my whole system, still have the issue - it works on 4.13 but not on 4.15. (A side benefit of reinstalling my whole system was that Arlo thinks my cameras are “new” again and now I have another 3 free month trial of their cloud, so at least I will have remote access until hopefully this is fixed.)
I'm am told their “higher level” team is looking into the issue now.
kamranbaig
I am using IOS and never had a problem with old hub which has been replaced some weeks ago. I could access my camera's and videos any where in UK or outside UK.
This new hub, automatically updated Arlo new version and now I can't access my video clips any where (other than home network). I contacted Arlo and been told there is a problem with Arlo which they are trying to fix and since than I am waiting for this fix.
In my opinion, there isn't any problem with IOS, the real problem is with Arlo.
The facts are that it
  • works using the Android app
  • works with a home VPN using the iOS app
  • fails with port forwarding using the iOS app.
You can draw whatever conclusion you like from the above.  My own conclusion is that there is a problem with the iOS app.
