Ultra not detecting motion. Performed motion detection test and light is not flashing.
  • 5 Replies
  • 2025 Views
  • 5 In Conversation
Theokayman
I know this has been covered under several threads, but none seems to match the issue I’m having. I have one Ultra camera (out of 5 total) that is not detecting motion. I performed the motion detection test and the light is not flashing. I deleted the camera and re-added all of them to the Base station. The other 4 are working fine. The firmware shows up to date. What else am
I missing?
5 REPLIES 5
dcfox1
Have you rebooted the cam itself (removing and reinserting battery). This fixes a lot of quirks.
robot-monster
Having the same issue with one of my 4 cameras, and it is the one that is protected best from the weather, although it's not bad where I'm at. Tried rebooting, removing battery, checked on firmware updates, etc. Stopped about 2 weeks ago. Other cameras have no issues.
Timkimwm
I have the same issue
Camera working if you press play but no motion detected
Have rebooted,  changed motion sensitivity, even bought a new battery but no luck.
Have you removed the camera and reconnected it in the app?
robot-monster
Yes, removed and reconnected the camera in the app as well. I'll give it another try after work.
  • 5 Replies
  • 2026 Views
  • 5 In Conversation
