My Ultra cameras have missed some motion activation that the Pro 2 cameras have recorded. The Pro 2 has videotaped a cat several times that the Ultra Cameras have missed. A person has also been missed by the Ultra cameras.
My question is do the Ultra Cameras have the same motion detection mechanism that the Pro 2 cameras use?
Can the motion detection of the Ultra be improved in the future with a firmware update or is it as good as it will ever be due to a Ultra hardware problem?
Hope it is something that will be fixed or I may end up using the Pro2 as a trigger for the Ultra
Some things to note, be sure that the cameras are not too close together. This could cause interference issues which could result in some of what you're experiencing. Try positioning the cameras at least 6 feet apart and test again to see if you get better results.
You might also try increasing the sensitivity for the Ultra camera, while the technology used for motion detection is the same (PIR), there are hardware differences that could result in slightly different behaviors.
The development team is currently investigating these reports.
addertay,
Thanks for the update, please let me know if you experience any new issues. I'm communicating your feedback now with the engineering team.
Accessing Local Storage
