The camera device does not working
The camera is defect within 1 year. The battery is good but the camera does not working. I try many times takeout the battery and put it in again and connect with the power cable.. but it does not worked.. the same battery is working with another camera.
Discoloration around the camera lens.
The warranty is 1 year - if you are still covered, you should probably contact support and ask for a warranty replacement.
Accessing Local Storage
