  • 2829 Views
Dumdidum
Hello
I have 6 Arlo Ultra cameras which do work find in the mode "Active". Togehter with the Smart Abo, it does record and push a message with person/car/animal...
But: I am using Geofencing (at home, only 1 cam active, and at night 5 cams active). "Custom Mode Outside"
There, i have the problem that some cams only detect motion but do not record. So it is working correctly with the basic active mode, but when I select my custom mode "outside", only 2 of 5 cams are recording correctly, the other 3 only detect and push a "motion detected"-notification, but without screenshot and no recording.
What might be the problem?
As said - the cams itself are working correctly in the activated-mode, which activates all cameras, but not in custom mode.
Checked all the setting and the 3 cams have the same settings as the 2 which are working correctly...
Very strange and annoying...
Any suggestions?
dcfox1
Was just going to suggest that reading the first post, It is common to miss.
Dumdidum
Argh. My bad.
I did not add a camera to record.
So - I am happy with Arlo Ultra - although it's quite expensive...
dcfox1
Dumdidum
Thanks - in the app this wasn't really straight forward.
Did notice it in the web frontend.
  • 2830 Views
