Initial setup shows smart notification option - since I moved 2 camera to deactivated the smart notification option is no longer in my setting
Please help
ArloUltra83,
When you say the cameras are "deactivated", what do you mean?
If you've made the cameras "inactive" within Arlo Smart, you will not be able to adjust any Smart features.
Hi James,
This relates to my other post - lag on motion detection.
In order to deactivate Smart analytics, I went into Settings --- ARLO SMART ---SMART Notification ----> Moved active cameras to Inactive.
****Mind you this does not improve the lag on motion detection.
So after placing the cameras into inactive, when I go back to Setting, ARLO SMART Option no longer listed in Settings.
I found a solution but a lengthy process.
In order to get it back. I need to remove all devices and go through the setup again from scratch.
Accessing Local Storage
