There's typically a 5-10 second reset time. The issue with "record until motion stops" that many folks don't seem to grasp is that if the motion can't be detected by the camera recording will stop (~5 seconds after the loss of detection based on my testing quite some time ago). If the object resumes motion that can be detected by the camera, the recording will start again after that reset period is finished. For that reason, use of timed recordings may well be the better choice. You can test this on your own by moving like a previous subject did as well as checking the distance from the camera and sensitivity setting.
Accessing Local Storage
