  • 2 Replies
  • 829 Views
MrDman
I have one camera that is at the edge of the base station range.  It seems as if the camera is more reliably accessed after I reboot my Nighthawk router.  What is the explanation for this behaviour?
Hard to say.  If could be that the router transmitter is aimed towards the base or the camera, causing some interference.  Or it might be more about the connection between your viewing device (phone/PC).
How sure are you about the correlation?  Does restarting the base have a similar effect?
MrDman
Tests didn't confirm.  So, maybe it was an fluke.  Since then, I've added a Smart Base at another POE to solve my problem.
Thanks for your reply.
  • 2 Replies
  • 830 Views
