PICTURE PINK
  • 2 Replies
  • 1391 Views
Nsmith82
our video feed live and recorded is pink and green. I Uninstaller, turned off, reset hub, and replaced the battery. Fixed one time then went back and now won't work. Any suggestions or foes anyone know if arlo will replace it?
n1976jmk
Virtuoso
Virtuoso
Remove battery for at least 30 seconds, if you have AC power connected remove that as well completely.
Let us know if you have AC power too?
I have had a pink hue a couple times in past occur randmonily and the way I fixed was remove battery and AC power from camera.
If it continues, use the Contact Support link fro a hardware problem.
  • 2 Replies
  • 1392 Views
