One (of several) cameras going (temporarily) offline out of the blue. Goes back online after a while
Dear Community
I have vandalism going on on my property and the cameras failed recording the acts. Very very annoying.
I installed 5 cameras and occasionally one of them (not always the same...) goes offline out of the blue (while the others keep working). After a while (5-45min) the camera is online again.
The base station is connected to the router by ethernet cable, the camera is within 15m from the base station, the battery is fully charged, and the firmware is up to date.
Any idea what the issue (and solution....) could be?
Will put his twitter link below and twitter name
(DIRECT MESSAGE HIM)
https://twitter.com/mbmcrae?s=21
@mbmcrae
Many thanks.... would you have an email for DM the CEO?
Hopefully this will help
Sometimes one of my Ultra cameras will freeze and when I go into 'live' view, I would get an error that the camera is offline.
All my cameras are powered via USB cable to wall chargers.
What I usually do to solve this is:
- Unplug the USB power cable, of the camera, from the wall charger
- Plug the USB power cable, of the camera, back into the wall charger
After I do the above two steps, then I can go into the 'live' view and it will be working again.
Thanks a lot for your feedback. Probably a good solution, but not feasible for me as the property is a 30+ min. drive from where I generally live. But thanks anyway a lot!
You won't be able to troubleshoot anything until you actually are there. There is not a way to reset the individual cameras remotely though I wish there were.
I have 16 of these cameras and 4 base stations and have the same issue. Random outages.
I suspect it is the back-plane of the Wireless Base station that can't handle the the high load of this image quality. So it just errors out and reboots.
Many thanks. That's understood. I was hoping to find a solition that minimizes the risk of the camera going offline.
Sounds logic. But annoying, of course. Rather than bringing out a new door bell, Arlo may want to make its existing products stable...
You could plug the USB charger into a digital timer. You could then program the timer to 'off' for a minute, every four hours. This would regularly 'turn off' the power, however your camera's battery will maintain the camera so that it will continue to record during the those minutes it was not powered from the wall.
Accessing Local Storage
