One of my cameras can’t live stream and my CVR plan stopped recording after 22th October
  • 4 Replies
  • 3840 Views
castortroy86
I can live stream 3 cameras on my phone, but not camera number 4 and the vcr plan on that camera. However, on my MacBook all 4 cameras can stream
Does anyone else have similar issues these last hours?
ShayneS
Are you trying to live stream all 4 cameras at the same time? Can you stream the the 4th camera by itself?
Can you try removing and re-installing the Arlo app.
castortroy86
I can stream the other cameras, but not the 4th with the vcr. It cant be streamed as the only camera playing or together with the other ones
castortroy86
Have also turned my phone on off and reinstalled app. Also restarted hub. I can live stream on the MacBook but it don’t have the vcr recording’s
I don’t have any vcr recordings after October 22. I can view my camera from my phone on the video settings option though, but not through live stream. It just keeps loading. On my computer I can live stream normal, bur thr vcr recordings after October 22 is gone
ShayneS
I have escalated your case & someone from support will be reaching out to you as soon as possible.
  • 4 Replies
  • 3841 Views
