Is it possible to change the size of the shaded area during camera positioning?
Hi
Is it possible to change the size of the shaded area during camera positioning so that the motion trigger zone can be more specific ?
This can be done on Ring so I assume there must be a way for Arlo but I have not been able to work it out yet.
No. The PIR sensor would need to be masked to pull this off. Cameras such as the Arlo Q use pixel-based detection which might do the trick but I haven't tried that. I just set up to try that as a test.
Accessing Local Storage
