							How to get the WiFi password for SmartHub? Tried resetting 3 times.
Can you someone tell me where I get the WiFi password for the smarthub? I’ve reset it three times and everytime I follow the steps in the app to add the smarthub. I select the VMB WiFi and it keeps asking me for a password.
You don't (and can't) connect to the hub's WiFi - there's no need. The hub is connected to your network via an Ethernet cable. Claiming the hub simply means you have to be on your home WiFi, not cell service, for setup - afterwards all you need is Internet access, however you get it.
						Accessing Local Storage1
						Arlo Mobile App282
						Arlo Pro 31
						Arlo Smart180
						Arlo Ultra9
						Before You Buy434
						Features290
						Fehlerbehebung1
						Firmware Release Notes39
						Installation300
						Online and Mobile Apps113
						Service and Storage110
						Smart Subscription3
						Troubleshooting1,827
