How many kw Arlo Ultra Base Station uses?
Hi,
I am a boat owner and I am pondering between Arlo Go and Arlo Ultra with two camera setup. Ultra would fit better for my needs as I wouldn’t have to get two different sim cards and data plans. I have already a wifi router onboard which is connected to LTE network (has a data plan)
So the questions is how much power Arlo’s Ultra Smarthub VMB5000 model uses in kilowatt-hours? I didn’t found any information.
Power of course is kilowatts (or watts), not kilowatt-hours.
I'm not seeing power specs on the datasheet or in the manual. However, the power adapter spec is 12v@5 amps (or 60 watts). So it won't be more than that, and likely is quite a bit less.
Accessing Local Storage
