How many cameras will ultra SmartHub support?
  • 2 Replies
  • 7334 Views
Grant66
I have 3 arlo pro cameras with a SmartHub, and I want to upgrade to arlo ultra system(2 ultra cameras + ultra SmartHub), question is how many cameras will ultra SmartHub support?  Does it (3 arlo pro + 2 ultra cameras) can work with ultra SmartHub well ?
Grant66,
The number of cameras supported is limited by the subscription plan.
For information on what each plan allows, take a look here: What are the available Arlo subscription plans and how much cloud recording is available?
I haven't heard this specifically but if it's like the older bases the answer is 15 cameras can be connected. At least on the older bases, only 5 can stream at the same time. No idea if newer hardware has removed that restriction.
Short answer is that the 5 cameras you want to be connected will work fine.
  • 2 Replies
  • 7335 Views
