  • 1 Reply
  • 5464 Views
  • 1 In Conversation
Blacky17557
Hi. I have just set-up my Arlo Ultra Cameras at home. I was wondering why the USB Port had been removed from the New Ultra Smart Hub and then noticed somewhere on this site that there is provision to use a Micro SD Card with the Smart Hub.
It took some time but I located a slot underneath the Smart Hub that looks like it would accomodate a Micro SD Card.
I inserted the card but unlike any other Micro SD Card Slots where you push the card inwards and feel a spring - then push further until it locks - this was not what I experienced. The card does fit into the slot but because there is no spring mechanism the only way I could retrieve it - was using a sharp knife to lever it back out.
I'm sure I must be doing something wrong and would really appreciate someones help please?
Thanks!!
Blacky17557
Hi.
Sorry - I was finally able to work this all out - SD Card now active and all good.
Sorry for the early post - should have read the manual first.
Thanks!!
Blacky17557
Hi.
Thanks!!
  • 1 Reply
  • 5464 Views
  • 1 In Conversation
