Geofencing with Outdoor vs. Indoor cameras + schedule
  • 2 Replies
  • 1119 Views
geronimo19
Hello,
I have seen a few posts regarding this but they did not fully answer my questions. Hope the community can help.
I have 5 ultra cameras at home: A/B/C are outdoor cameras and D/E are indoor cameras. Here is how I'd like to set them up:
- A/B/C outdoor cameras always armed (regardless of if I am at home or not)
- D/E indoor cameras only active in 2 cases: (1) I am not home (geofencing) OR (2) I am at home but it is between 10pm and 6am as defined in the schedule mode.
Is there a way to support this? Not at home: all cameras always ON, I am at home: outdoors cameras ON, indoor cameras only ON between 10pm and 6am. Within geofencing, i can easily arm all cameras while away but while at home I would essentially like to using the schedule mode for indoor cameras and armed mode for outdoor cameras. I am not sure this is possible... Any idea?
Geo give you two modes ;  Away and Home
You'll may need to make some custom modes
So GEO away is ARMED ( easy part as all are on )
GEO Home is a bit tricky as Schedule
(tips ; any cameras NOT in active mode are off )
(tips; go thru midnight must broken broke into two parts up to 1159pm, then Midnight on )
(tips; only one active mode can run at a time )
Schedule using created custom mode with cams   ABC
use Schedule to arm ARMED for times of 10 pm to 1159pm, next day Midnight to 6am ( all on while home)
use Schedule for all other times, mode ABC ( abc armed during rest of time while home )
think that should do it   🙂
geronimo19
Hi TomMac - yes! This worked for me. Thanks for your help.
  • 2 Replies
  • 1120 Views
