							Flashing amber
Amber light flashing continuously but the cameras appear to be working ok?
did reset with all the hassle of starting from scratch, blue light for one day now back to flashing amber! Anyone know what is wrong! Need help 🤷🏼♂️
Sounds like a communication issue between the cameras and hub:
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
It may be a transient issue but try moving the hub away from the router. Check the signal strength icons for each camera to verify the connection. Look for other wireless devices that may be interfering with the connection.
Flashing amber intermittent, but all 3 cameras working fine!  Me thinks it is probably wi fi communication between Arlo hub & EE router ?🤷🏼♂️  maybe try repositioning both? Before the warranty expires.
been working fine for 22 months!
						Accessing Local Storage1
						Arlo Mobile App282
						Arlo Pro 31
						Arlo Smart180
						Arlo Ultra9
						Before You Buy434
						Features290
						Fehlerbehebung1
						Firmware Release Notes39
						Installation300
						Online and Mobile Apps113
						Service and Storage110
						Smart Subscription3
						Troubleshooting1,827
