Disabling siren on the VMS5340 / Arlo Ultra setup
Hi,
I would like to disable the siron feature on the Arlo Ultra cameras as this is not required and, if triggered by accident, could lead to people being startled.
I've seen there is a lot of entries in the forums around this subject but I haven't yet found a definitive answer to this.
I was looking at the web interface for the system and found this
This has not been ticket, as you can see. Does this mean the siren is disabled or is there another setting that is needed?
I am not able to see the image that you posted.
On the Ultras the siren is a function of the cameras instead of the base.
Under modes, if you have a rule per camera, that says turn alarm on, then just uncheck the box next to that setting.
This has not been ticked, as you can see. Does this mean the siren is disabled or is there another setting that is needed?
Yes, it means the siren is disabled. It's easy to confirm this - just walk in front of the camera to trigger the motion detection.
Accessing Local Storage
