app version: 2.16_27097
See pic
If I'm understanding your question, keeping in mind that it can only be accessed in the phone app and under the main login. When you go to library you should have a choice of cloud or SD. Also keep in mind that is only if your phone is on the same network as the Arlo hub and if away from home you must have set up either VPN or port fwd.
@timi wrote:
Hi folks, I can't find anywhere the Direct Storage Access button, am I missing something?
Direct Storage Access should be right below the "Overwrite Automatically" control in your screenshot.
Can you confirm the model of your base station?
attached version and hub model.
You're in the wrong place - it's not in Device Info. When first going to the hub's settings page you should see a Local Storage selection.
Settings, my devices, name of your system, SD at the bottom
your screenshot isn't showing direct storage access toggle
what type of phone are you using and do you have the latest ver. app
That's the latest android ver. so I'm not sure why the toggle would not be there. You would probably have to contact support. The first thing they will most likely ask yo to do is to uninstall the app and re-install it.
@timi wrote:
exactly, because I don't have it! or don't know where to look for it, can someone point me where to find it?
You are looking in the right place. As @LandJS suggests, you could try reinstalling the app.
Or just contact support: https://www.arlo.com/en-us/support/contact.aspx
Accessing Local Storage
