Continue to get sound alerts from one camera. Called support team but cannot help.
  • 2 Replies
  • 1040 Views
Jimalex1957
I continue to get Sound Alerts from one camera.  When a car goes by I get an alert. I have  called technical support and they cannot seem to help.  They cannot remote in to my system to see what is going on.  Just a little disappointed with what should be a pretty simple issue.  Any  help is appreciated.
dcfox1
Make sure you have "Audio is detected" unchecked in the rules for that camera if that what you mean by sound alerts. If you mean motion recordings try to turn down sensitivity in rules or try to reposition the view of the cam.
What are modes and rules and how does Arlo use them?
dcfox1
Jimalex1957
I think that this might be  it, it was checked on my settings.  As simple as this is I would have  thought Arlo support would have walked me through that step. thanks Doc.
  • 2 Replies
  • 1041 Views
