Cloud recording showing up late
I am runnig into issues with my Arlo Ultra. Like others have mentioned, my set up misses motion or sees motion and does not record to the library, especially at night. Now, I have a new issue on top of that. Over the past few days, I will recieve a notification of motion. I will then check the library of the camera the motion occured on and no recording is showing. Then, about 5 or 10 minutes later, the recording shows up. Previously, when Arlo did record, the library video would show quickly. Any ideas of what could cause this. My app is up to date and I have tried signing in and out of the app with no luck. It occurs on all cameras that pick up any motion. Any help would be great!
Not sure if its just a fluke but mine is showing up quickly now. Also I just turned off my Activity zones so its possible that was causing the issue
If not by swiping left on the Zone tab under the display, try pressing and holding. I'm on IOS so swiping left is how I delete the tabs of zones I have created.
Just wanted to make sure you knew that by de-activating activity zones it solves the problem. So the culprit maybe lies within that area. Just thinking you could pass along the info. Thanks
goes without saying
It would be nice to get some kind of update as to what is happening. I would like to see if they are working on updates to the zones that we are paying a premium for that aren't available. I am getting inudated with alerts as I am unable to create zones on my property. I have an animal that is outside all day and am now constantly getting alerts all day long.
What's the update on this? It's been close to a month since this was first reported and still no fix from Arlo on this??????
This is a major issue and this system is completely useless right now!
I guess i am disappointed with communication from Arlo. This is quite a big issue for some people, one would think they would be posting updates on each of the know issues. I would also hope that after they get the issue fixed they would offer a free year of Arlo Smart Premier as a good will gesture for the issues they created
Accessing Local Storage
