Changed WiFi password how do I get my cameras connected
  • 2 Replies
  • 880 Views
lovemycameras
I changed my WiFi password
cameras disconnected, the router is directly plugged in from WiFi to Arlo box so i dont know why its not working
help please
The Ultras only connect to the smarthub, so just changing the password for your wifi shouldn't have any effect at all. Did you switch to a different router, or otherwise change the ethernet connection to the Arlo hub?
Are you seeing the Arlo Hub as on-line in the app?  Or is it also showing up as off-line?
Also, what is the hub's LED showing? Should be solid blue.
  • 2 Replies
  • 881 Views
