Cannot turn camera on or off from app
  • 9 Replies
  • 1215 Views
audude08
The “device and off” toggle disappeared from settings. How do I re-add it to the app?
9 REPLIES 9
@audude08 wrote:
The “device off” toggle disappeared from settings.
Do you see "Library" in your app menu?  Or do you instead see "Feed" and "Dashboard"?
I have the "Feed" interface, and I do see the on/off toggle when I go to the Devices tab and select the camera settings wheel there.
audude08
I see “Feed” in my app.
audude08
audude08
But it is not showing on my end.
Odd.  Are you using the primary account?  Or are you using a "friend" account?
Also, what version of the app are you using?  Mine is 5.7.6 (9253)
audude08
I am using the “friend” or “shared” account. I am using the version 5.7.6
Has this account been granted "access rights"?
audude08
No, my mom is the primary holder. I just have granted access under my own account.
I don't understand your answer.
If your mom granted you access rights when she shared her cameras, then you should be seeing the on/off control.
So I think the next step is for her to check that "Allow Access Rights" is switched on.
If it is switched on, then I think there is a bug in the app.
  • 9 Replies
  • 1216 Views
