Cannot record on microSD
Hello
I have an Arlo Ultra with a micro-SD-Card (8GB, for testing) inserted. It's formatted using the Arlo App and shows "0GB out of 7GB used..." (translated from german)
But nothing gets every stored on the micro-SD-Card.
I have turned all on in the settings, it is also shown on each cam (dark-gray instead of light-gray of the mirco-sd-symbol).
But nothing gets recorded.
What could be the reason?
Are these motion triggered recordings ???
Live view and a manual record do not go to the mem card.
I believe there is a 16 GB min. Won't swear to it but it has come up before
Correct.
Accessing Local Storage
