Canada
Responder
  • 1 respuesta
  • 4307 vistas
  • 0 kudos
  • 2 en conversación
Kltaief2022
J’ai besoin dés problème avec la charge des camera qui normalement pourra atteindre 6 mois alors qu’il ne retiens que semaines
de plus il y a un problème de charge ?
1 RESPUESTA 1
How long the batteries last depends largely on the amount of streaming/recording the cameras have to do.
Can you estimate how much recording is going on? Note that activity zones conceal the amount of streaming (because the cloud does the processing, and discards streams that are outside the zone).  So you need to remove them for a day or so to make this test?
A second factor is the signal quality.  A poor signal to the camera will also hurt battery life.
