Weird. Check the time zone in your base settings and then reboot the base. Any better?
Thanks @jguerdat, but unfortuately no. Still the same. Firmware is up-to-date. It looks to be an issue with the IOS app. I’m running that on IOS IPad Pro. I’ve checked on my Android phone and am able to update the schedule, so there’s a workaround.
Tastyrabbitpie,
Do you see the same behavior using the web client? If you set the schedule there and go back to iOS, do you still have the same problem?
Hi @JamesC Thanks for the follow up. No, I could update using a web browser and via the android app, so no problems there. Those updates also came through in the app on the iPad. Not sure if there has been an update ( I should check), but it looks like the issue is also resolved in the IOS app on the iPad. When I edit the schedule on the iPad the time selections are correct and save as selected.
I’ve got questions around setting an activity zone as that doesn’t seem to work, but I’ll search the forum for answers first and/or raise another ticket. Unless you’ve got any advice or links that may help get that working right, that would be awesome!
Cheers
Matt
Accessing Local Storage
