  • 1 Reply
  • 1571 Views
chrisreve89
I have a 4 camera Ultra system. Three of the cameras are fine, but one is on the hairy edge of the reception area for my current base station location, which unfortunately can't change.
I have a few questions....
1.) Is there a camera that I can add to my system that is direct wifi and does not need a base station?
2.) I want to add a Pro 3 floodlight to my system. Do I need a different base station for that or will it connect to my existing one?
3.) If the floodlight/camera needs a separate base station, I can add a pro 3 camera to it to replace the ultra with the range issue, since the second base would be much closer. Can I then see all 6 cameras (4 ultras, 1 pro 3 and one pro 3 flood) within the same instance of the Android app?
1) A Pro 4 connects to WiFi or hub.
2) No - existing hub is fine.
3) Yes.
  • 1 Reply
  • 1572 Views
